Quick background. '08 VW Beetle 2.5l , ~160k
Factory interval is 10k, however I shoot for no more than about 7500k due to age of engine, possible consumption in the past, and personal preference.
The last time I changed the oil I used M1 0w40 Euro on the recommendaion of several members here. This oil had 7785 miles (couple hundered more than I normal aim for). Before draining it, I checked the level and it was at least 1.5 QTS low. I topped it off to see exactly how low it was, even though I was about to drain it.
Now, the previous two changes before the M1 were using Demo 400LE Syn 5w40, followed by Rotella T6.
Each of those ran for ~7500 miles without any noticiable loss of oil on the dip stick.
So, needless to say I went back to the T6 this time.
Anyway, I am not here to say anything negative about the apparent loss/consumption/evaporation of 1.5 QTS of oil while using the M1 (we all know that many OEMS would have no real problem with 1.5qts of use over 7500miles), but I am more interested in learning why there is such a difference between the M1 and the two diesel oils I used.
Would this be something related to NOACK numbers? I wasn't able to find any offical specs on any of the three oils, but I saw someone posted the M1 is 8.7
If it isn't NOACK, what other properties of the oil, or what about it would end up making one use 1.5 QTS, while the other two immeasurable?
Is this the difference between diesel oils and gasoline oils?
