Loaded 91 octane tune (Steeda CAI with insert) from James. Acceleration is much faster than stock and steeda tunes. However, I am not sure if the shift is still harsh. When shift was harsh using steeda and stock tunes, I felt like being pulled from behind then return to normal speed when changing gears. With the tune from James, I felt like being first pulled from behind slightly then pushed forward slightly then return to normal speed when changing gears. How does it feel when shift is normal? I haven't driven many cars and there are no experienced drivers I can ask.
These two videos were taken after loading the tune from James. One is normal acceleration, and the other is WOT. RPM seems to be higher than stock settings when shifting. What's you guys opinion on the shift points?
https://www.dropbox.com/s/5a4x1myic30x9qb/Normal acceleration.mp4?dl=0
https://www.dropbox.com/s/v3f4ez8xgtag778/WOT.mp4?dl=0
My car is 2012 Fusion V6 3.0 FWD with about 40k miles.
