Originally Posted By: Exhaustgases
He said the "target engine does not have" silver bearings.
So that is not the issue. And no need to consider aviation motor oil.
Far as I know, only EMD and GE engines have silver plated bearings. Some EMD engines in non locomotive application don't have silver plating. Thus came to this conclusion on an engine oil test.
Quote:
The research team recommends that Galveston Ferry Operations begin using Exxon Elite
20W50 in all of its ferries. Although this is an airplane piston engine oil, aircraft oils are
necessarily designed to minimize wear due to the danger resulting from an engine failure at
altitude. Thus, it was not surprising that this oil had the lowest rate of change of wear metals of
all of the oils tested. Additionally, like all aviation piston engine oils, Exxon Elite has no ash
whatsoever. Thus, it was also not surprising that Exxon Elite also had the lowest rate of
accumulation of calcium deposits. Exxon Elite also had the second lowest oil consumption rate.
Good article
Galveston Ferry Operation (GFO) Engien Failure Assessment
