Originally Posted By: Mystic
Originally Posted By: wemay
Here i go, top five for me:
P-47
Spitfire
FW-190
Mitsubishi Zero
F4U Corsair
I did some research online and came across some information where experienced pilots had talked about various fighter planes from WWII. The more you find out the more difficult it is to say which fighter plane was the best.
No question about it-it was very important for fighter planes to be able to escort bombers all the way to the target and back and the P-51 was very important. But there were a lot of good and bad points with all of these various fighter planes.
For example, some actual mock dogfights were carried out with Hellcats and Corsairs and the Corsairs were better! Although there is no question what the Hellcats achieved in actual battle. But by the time those battles took place the skill level of Japanese pilots had been greatly reduced. It may not have mattered much if the American pilots had been flying F4Us or F6Fs or whatever. The Hellcats were easier to land on aircraft carriers.
And the German Me109 (which apparently should actually be called the Bf109) was an incredible fighter plane that was built in greater numbers then any other and flew for a very long time (into the 1960s for some countries) and had great firepower. According to some of the information I found online it was very comparable to the P-51. The FW-190 was also very good.
Maybe what was really important was which country was able to produce more quality fighter planes and train more pilots. Because of destruction of factories the Germans were less able to produce as many fighter planes as they needed. The same thing happened with the Japanese. But the Japanese also did not really have a good replacement for the Zero. They had some good fighter planes but they were not able to produce those fighter planes in adequate numbers and they started to run out of very good pilots. The USA had a lot of good pilots and the quality of USA fighter aircraft improved as the war went on. By about 1943 or 1944 the Zero was no longer the awesome aircraft it had been early in the war. And the Japanese started to run out of really good pilots and could not produce even enough Zeros.
Actually, Japan did have a few great replacement aircraft for the Zero.
While the Zero gets all the attention because of it's superiority early in the war....and the great numbers that Japan was able to build of these aircraft...many other worthy fighters existed.
Some of Japan's very best fighters came out late in the war. They were pretty much equal in capability to allied fighters. Sadly, for Japan, these designs came out in too little numbers and too late in the war to have much effect. The U.S. bombing raids saw to that as well.
The following aircraft were outstanding:
Kawasaki Ki-64 "Tony"
Mitsubishi Ki-100
Nakajima Ki-84 Hayate "Frank"
I didn't include the copies of the Me-262 and other oddball anomalies that Japan got from Germany.
