I have a Powermate generator that I can't get started
Clean gas... Good spark plug... Clean air filter
414cc LTC engine
Model #: 12125H0609326A. (Stamped on engine)
Removed & cleaned the carb. Bowl has gas in it when removed and the float moves freely. Cleaned/Sparyed every little port I could find
Checked and cleaned all fuel lines with carb cleaner along with a flush of fuel filter and reverse blew carb cleaner back into the tank to make sure free of debris. Finally, blew carb cleaner thru fuel line from tank to carb and worked the fuel cut off back and forth at the same time
If I shake the unit and slosh the gas around, I can get it to turn over but it then quickly sputters out.
Until has only 29 hours on it since Sandy and I try to turn it over a couple times a year. Last fall, started and ran like a champ.
Now? Darned near threw my back out yanking on that GD pull cord
Any thoughts as to what could be the problem?
Thank you
414cc LTC engine
Thank you
