So i have a 2009 V6 camry, there is a "drain" plug for the ATF and fill plug.
http://www.toyotanation.com/forum/104-5t...flush-pics.html
Found a DIY that seems to be a lot of hassle. I was thinking of just using buying a mityvac 7201, use that side fill plug, suck out 1-2qts and refill. Do this every oil change (7500 miles) and call it good. Would the mityvac 7201 do this job for me flawlessly?
I never had a reason to get a mityvac since all my cars had drain/fill plugs with dipsticks. All filters on the bottom as well so the whole never jacking up the car isn't there.
