Originally Posted By: B320i
Originally Posted By: Gokhan
What is forgotten in this discussion is that conventional 5W-30 and even many synthetic 5W-30 oils shear to 5W-20 anyway; so, there is really not much difference in viscosity between 5W-20/0W-20 and most 5W-30 oils.
5W-20/0W-20 oils that are commercially available are very close to xW-30 weight and they are more shear-stable than xW-30. Any car that can tolerate 5W-30 should be able tolerate 5W-20/0W-20.
The only exceptions are ACEA A3/B3(/B4) xW-30 oils. These are what I call "xW-35" oils and are closer to xW-40 than xW-30 in weight. Neither xW-20 nor regular xW-30 should be used if such "xW-35" is the minimum viscosity specified.
Turns out there are actually BMW LL-98 0w20 oils. Well, precisely one based on my research. Google it(!)
My opinion on the subject is this - modern engines are built much tighter than older ones, and thus require a thinner oil to ensure adequate protection. A thicker oil won't get in the tight areas as well as a thin one would, regardless of temperature of what silly oil manufacturers say.
I'm not sure about filter technology, but wouldn't the OEM's have figured out some sort of system to ensure that filtration remains superb during the interval specified to ensure minimal wear?
(What I am thinking of here is something like the centrifuge filter found on the Rover TD5)
Absurd.
If a 20 cold is getting into those tight spots then a hot 40 grade is easily getting there.
Nonsense.
Absurd.
Nonsense.
