FYI, here's a picture of the timing system on a 4.7. The yellowish pieces are the timing chain tensioner "shoes" that should be inspected if possible:
And YES, standard procedure is to wire-tie the chains in place and leave them around the intermediate sprocket when R&R-ing the cams or heads. But with the heads off, you should be able to get a pretty good look at all of the guides and tensioners except maybe the two on the chain from the crank to the intermediate sprocket.
they tie them in place to maintain position? Im familiar with honda timing belts and old pushrods but this setup is new to me
