Post Your Latest Coolant Change.
Call me lazy but Ive never pulled the lower or upper radiator hose just to do a coolant service.
I just drain, refill with tap, drain that, and then refill with an appropriate 50/50 that I mix on the spot.
Any real benefit to pulling the hose? I figure it adds risk...
Lowers risk. You don't wear out or risk stripping out the plastic threads of the drain plug. If you have the old fashioned petcock (metal), there's the risk of rust seizure.
What's also nice is with the lower hose off you can put your garden hose in the filler and use your garden hose for a power flush rather than wait for it to dribble out of the pin hole (also can jam the garden hose in the lower hose for a block flush of sorts).
Even worse, sometimes the radiator could even crack when pulling the drain plug, if it was a weak radiator with plastic end caps and several years of use.
2004 Mazda RX8
Two gallons of yellow/green Mazda OEM coolant out.
Two gallons of pink P-HOAT formula Zerex Asian 50/50 pre-mix in.
$13.99/gallon at NAPA.
2003 Toyota Camry 3.0L w/144,000.
OUT: Blackened, formerly multi-colored GOK (God Only Knows). Rinsed to clear.
IN: Zerex Asian (pink), new thermostat, gasket and water inlet "O" ring.
LESSON LEARNED: USE ONLY TOYOTA PARTS. The aftermarket thermostat (Stant) was garbage. Kira
02 s10 4.3L
Out: sludged dex cool.
Replaced the leaking and eaten up intake manifold gasket
Filled with distilled water and a bottle of prestone rad flush
Drove for a week, drain and fill with distilled water only. Repeated this for the next 4 weeks.
Then drained and filled with 50/50 supertech all makes all models coolant and distilled water.
Replaced thermostat with another oem.
No leaks and the truck runs at 195 degrees (as per the stock thermo)
98 chevy 5.7 z71
Out-can't remember but I'm pretty sure it's Peak. Looked really good. It was in for bout 3 yrs.
In super tech amam after several flushes.
2006 Saturn Relay 3 with 3.5L, 128K miles.
Out - Assuming factory fill Dexcool
In - Simple drain and fill with Prestone Dexcool mixed 50/50 with distilled water. Approx 6 qts.
Will probably do this again in 3 to 6 months.
All changed in the last 2 weeks
07 Mercury Milan (111K)
out: factory fill
in: Zerex G-05
1995 Lexus SC300 (201K)
out: peak global
in: Zerex Asian Vehicle
2000 Lexus GS300 (131K)
out: Toyota pink
1991 Chevy Corvette (55K)
out: who knows
in: Zerex original green
2009 Chevy Cobalt (161K)
out: factory fill
in: Zerex Dexcool.
2001 Chevy Camaro 3.8L auto (11.4 quart system) 95,000 miles
OUT: Careless mix (aka GoK -God only Knows)
Clean/rinse/flush with distilled.
IN: Dex-Cool concentrate. Bring to 50/50
NOTE: OUT was pinkish in color. Likely a mix of caught coolants from various vehicles.
Recovery bottle had ~1.5 qt. of an opaque frosty blue colored liquid in it.
2001 Honda Accord F23-A4. Three months ago. Replaced the original radiator with a new racing radiator (all welded aluminum type, the old one cracked just under the radiator cap, on the tank), OEM Honda Coolant, ~240K miles. Last flush was at 200K miles OEM coolant.
1987 Toyota Truck 4x4, 22RTE. Two months ago. Replaced radiator with new racing radiator (all welded aluminum type, old one was rotting from the outside, was brass/ Copper, custom 4-row type) at 365K miles. Used Zertex(Sp?) specifically for Asian cars. Last coolant change was done at ~350K with pet safe type.
1999 Ford Explorer with the 4.0L SOHC Cologne V6, 113K
Out - conventional green with some silicate drop out
In - G05 and distilled water after a 3-pack dishwasher detergent flush and fresh water backflush
2000 Ford Taurus Wagon
Out: 3 Year Old Prestone Green
1) Drain Radiator, fill with distilled water.
2) Run car to warm
3) Drain Radiator, fill with Prestone Long Life and Distilled Water.
2012 Hyundai Elantra GLS, 1.8L
Out: Hyundai OEM Long Life Coolant
In: Hyundai OEM Long Life Coolant
50/50 mix (50% coolant/50% distilled water)
60,000 miles
My very first coolant change, ever.
Drained original factory filled SLLC and cycled distilled water thru it 3x then added new coolant.
'05 Toyota Corolla LE
Out: factory fill
In: Zerex Asian.
Interval: 10 yrs., 114k miles.
