Originally Posted By: SilverSurfer
I think that graph might need to be adjusted just a little bit. How is detonation going to occur if the cylinder pressure is decreasing as indicated in the graph? I suppose heat could be increasing due to burning gasoline, but pressure is going down due to piston movement? That is the only thing I can think of.
The detonation occurs ATC because the end gases reached autoignition temperature, then ignited all at once, sending shock waves bouncing around the cylinder. That is what causes the spikes on the negative slope portion of the cylinder pressure curve.
If the remaining charge ignited all at once, shouldn't we see an instantaneous pressure spike?
I don't think the slope would get to be vertical, as there would be a finite time for the burning to complete. And as you said, the cylinder volume is increasing, so there is some fast burning occurring to cause cylinder pressure to rise during expansion.
