I would not drain the block drain, it's probably old, crusty, corroded, and you could break something.
When you drain the radiator, you don't "really" drain the engine, which holds about half your coolant. The water pump, thermostat, and various air pockets get in the way.
But draining the radiator drains the engine enough that you do get some air pockets, which burp out when it warms up. Typically about a quart worth.
I'd drain the radiator every night, for a week, and refill with tap water, and drive normally.
Then, for the last drain, use distilled.
Then, drain that and throw 100% pure antifreeze in. Considering the engine half being water, that'll get your 50/50 ratio back.
If you introduce tap water in your system, that's a SURE way to invite corrosion - I don't care if you do use distilled water for your last drain/fill.
Ed
