Hello Friends Bitogers!
One of my household vehicles Infiniti G37x has a front differential located so close to the engine that you can't insert a hand between the two. Given such a proximity of the heat source would it be advisable to use 75w-140 grade gear oil, especially in the summer?
Manual calls for 80w-90 in both differentials. Interestingly, and as a side note, for Sport model manual specifies synthetic 75w-90, even though it's the same differential as far as I can find.
Currently running Amsoil Severe Gear (SVG) 75w-90 in both front and rear. I did experience seepage in front differential, but it turned out to be a torn outer edge of the seal that allowed dirt to get in, thus affecting the seal of the inner lip.
Any input is much appreciated.
