Toyota V6 2GR-FE TGMO 0W-20 3rd OCI @ 9.5K mi
PA
TGMO 0W-20 and Toyota oil filter.
1st change- 1.2K mi
2nd change- 4.7K mi
3rd change- 9.3K mi with oil analysis (Nov 2014 to Jan 2015)
Dealer oil changes.
Cu & Sn elements are 8x higher greater than averages but maintains a 3-to-1 ratio like the universal averages.
Flash point lower than expected- 40mi(1 hour) highway trip each way to work. Cold winter??
Comments???
Sorry need to fix oil report link.
2014 Toyota Venza V6 9.5K mi
TGMO 0W-20/Toyota filter
Way too early to use a uoa data unless you suspect some problems the break in metals will be higher than normal.
Edit [4/17/2015 9:12 PM EST]: Updated the link. Simplified viewing the report without downloading.
