Originally Posted By: meep
what I can't get is how the arm finally let go on its own while the car was unoccupied. did it start as she was parking as a crack, then finish itself off while the car was sitting still? Was it cracked and then let go when she shifted into gear? did someone tag the tire or wheel while she was parked with a direct blow? was the bumper bumped hard enough while parked that it jolted the crack that was already started?
I bet it happened WHEN she parked (stopped). There was likely already a crack in the arm and during the what I presume was a typical turn-in-and-stop parking situation, there can be a good bit of torque on suspension components. Given the description, I'd say that it's like that the arm broke AS she parked/stopped. At that point, only the most observant driver would likely recognize it...since the car was nearly stopped or in the action of actually stopping already anyway.
Then, when they get into the car, engage the transmission, and release the brake, especially if there was any turning of the wheel while stopped to pull out, the wheel could have assumed any actual angle of motion.
I don't find the story hard to believe at all. I would report this to the NHTSA. If her vehicle is the only report of it, then it's possible that it was a casting fluke in that arm. But if there's a trend of this, there could be a larger issue looming.
It wouldn't be the first time a line of vehicles has had control arm problems, though I'd admit that most in the past have been corrosion related...probably something relatively foreign to a resident of Hollister, CA.
