Originally Posted By: supton
By the same logic we should not alter tire psi nor use after market non-oem parts. Looks like many here get away with it.
On my Jetta I always fill to the brim. My gassers tho I go to the first click and call it good.
Not the same things...the evap system is engineered to perform with certain parameters, when the design parameters are altered it causes problems (flooded charcoal canister) . It's not like you are switching from a Bosch O2 sensor to a Denso O2 sensor with both being the correct application for the vehicle.
