Speedometer quit on my 98 Chevy Truck almost two years ago. Posted on here about it and with help was able to locate the VSS, remove it, clean it up, reinstall and has been working since. Until last Saturday morning on the way to work it quit again. Did the same routine but this time it did not correct itself. Drove it a few times since and was going to order a new VSS from Rockauto until it started working again last night when I drove it!!
My question is do VSS's intermittently stop working when they are going bad or is it a part that will just quit? Just trying to determine if it is the VSS or if I have a problem with the electrical plug/wiring instead.
