Originally Posted By: Olas
Which factors do manufacturers consider when they spec the the PSI range for the valve to operate at?
Are there benefits to going higher or lower than recommended?
Most manufacturers are in the 9-13 psi range.....The only serious outlier I am aware of is Subaru, which specs about 21 psi.
Only the engineer who specced it knows for certain how he/she arrived at the figure. No real advantage to lower or higher.
If you run oil of the proper grade, and change the oil and filter at reasonable intervals, plus avoid revving the engine to high RPM on cold starts, it is very possible to never nudge the bypass open. Which is what you really want. On the other hand, even unfiltered oil is better than no oil, if you are an engine bearing.
