About to do my first oil change on the 09 camry V6. From what i've heard and seen its paper filters now and no longer cans.
I have 2 friends with camrys both 4 cylinders, an 09 and a 2012. Do they use the same filters? Thinking we can order bulk from OEM toyota.
I've research and found that they make METAL CAPS for these filters, i assume because the plastic housing is going to crack at one point. Its OEM as well... is this an issue? Should I invest in this unit?
LINK
Also how to do i remove this cap, looks like a LARGE socket is used for this. Seems that everything is a different size and what not. I would like to help my friends but obviously my V6 comes first before they 4 cylinders if the tools are different.
LINK
