P0123 High voltage at TPS.
Intermittent. Vehicle stalls when CEL occurs. Will restart and run.
Graph on code reader seems to indicate smooth operation of TPS. No obvious spikes or dips in the range. Reader only shows %, not actual voltage. Goes from about 12% to 78%.
Weird part: With key on, connector voltages are:
4.64 V, 7.2 mV, 5.16 V Shouldn't there only be voltage at one of the wires?
IAC was changed by a mechanic that said it was the problem (on a road trip at the time). Car ran better for a few days and then the same code returned.
Any help is much appreciated.
