That would be pretty poor engineering IMHO. On the Gen Coupe the t-stat is in the water pump at the lower radiator hose inlet. The ECT is at the back of the head where the water exits the block. Flow is up through the block and through the head and out to the heater core with an auxiliary pipe going to the water pump.
It's very efficient and with a bigger radiator the temp seldom gets above 185F.
