I have a Samsung S4 mini a little over a year old
I have witnessed 4 incidents where the phone battery discharges abnormally fast. Screen off, Wifi off, GPS off, All apps off, fair strength Signal, the phone just depletes the battery like the NSA is Spying on me, and the phone is noticeably warm.
It happened again today. from 90% to 15% in 2 hours, the only task, playing some music through a bluetooth speaker.
Usually I can use this BT speaker for 8 hours straight and the phone battery is still good for several more hours
Wifi was off, GPS off, No data used, mobile or Wifi.
I have a USB power meter. I recharged the phone to 100%, and left it plugged in. Any current it registers at that point is what the phone is using to ping the towers and run whatever else it is running.
It was using between 0.25amp to 0.40amps briefly jumping upto 0.55a , screen off, GPS off, WIFI off, BT off, all Apps closed., nothing indicating it was self updating, signal strength 4 of 5 bars.
Nothing I did, like clear the RAM, had any effect on power consumption.
Usually, when the battery is fully charged, the USB meter will read 0.00 amps, and sometimes read 0.05a briefly and other times read 0.20a for a second or two before dropping back to 0.00.
I restarted the phone and the 0.40 remained after it restarted and settled in, and then it dropped to 0.05a and the then the normal behavior, and has been acting fine since.
Anybody have any idea what is going on these times when it is in the mood to punish the battery?
