I've been performing regular ATF changes on my 2005 Escape by using an extractor to remove the old fluid via the dipstick tube.
This is really easy and convenient, but I've been wondering: if the drain plug is magnetic am I missing a step by not removing it and cleaning it of metallic residue?
Other than crawling under the car to get at the drain plug, one other downside is the maintenance manual's suggestion that the drain plug has to be resealed with Teflon tape to avoid leaks. To me this seems an opportunity for bits of tape to wind up in places they should not be.
Appreciate any comments. Thanks.
