Originally Posted By: bdcardinal
I also wish they made a Miata coupe, like an actual permanent hard top.
The LS engine option is better on a Miata versus the SBF for balance purposes. An aluminum block LS engine weighs less than the 1.6 or 1.8 that was in the NA and NB MX-5s.
I think the final weight though of the complete LS conversion, did add 50-80lbs depending on what accessories you wanted, AC, PS, etc.
I've never seen a V8 conversion car at our autocross's, but a few turbo's and one very fast S/C one. It has enough power, but still has the throttle response for racing around the cones. That car was usually in the hunt for FTD, even against the modded STI's.
I still had a blast in a 1990 116hp Miata, on its 10 year old original tires. It was still easy to adjust the balance of the car with the throttle and did everything it should.
