Originally Posted By: dustyroads
Originally Posted By: dailydriver
Originally Posted By: AMC
Chassis lubrication points are usually low stress applications which do not require a high performance grease. Mystik JT-6 Hi temp is an excellent grease and pretty much overkill for any type of chassis lubrication. It will certainly do the job and there is no real reason to switch.
If this was in response to my question, I was asking about the two
Mystik greases ONLY, not anything different, or from another company. (But thanks anyway for the suggestions.
Again, between ONLY the JT-6 Hi Temp red, and the regular, old, JT-6 clear, is one actually BETTER than the other for low temp, low speed, CHASSIS type lube purposes (i.e.; ball joints, A-arms, etc.)??
I don't have experience with basic jt-6 grease but it appears to be a good heavy duty chassis grease. The hi-temp has a wider temp range (not only a much higher temp use but also a little colder use).
The regular jt-6 is a higher viscosity (and subsequently harder pumping grease) so I'd hate to use it on my truck's many lube points, but fine for an occasional car/pickup grease job.
If you're already using the basic version I'd stick with it. Mystik's info says the basic jt-6 is calcium based and the hi-temp is lithium complex. I'm not well read on the subject, but I don't believe you should mix them. Others can shed a better light on the mixing subject, but you don't need to switch anyway.
THANKS for that info, and pointing out the different base stocks between the two Mystiks.
I may now switch to the red exclusively (of course after pumping out ALL of the regular stuff), since MANY more of the better greases out there are lithium complex based, and I could just use them IF I cannot find the JT-6 Hi Temp.
They are building a TSC store in Doylestown, Pa. and there is one now in Flemington, N.J., so at least I am not at the "mercy" of Sino Mart.
