Originally Posted By: Bladecutter
Originally Posted By: ISO55000
Again, with all due respect.
I did not post a "belief" I posted a fact. Popular opinion, voting, lack of understanding et al does not alter that.
automotive manufacturers do not have their own laws of physics, secret techniques or anything else.
I don't have to go "out there" because "out there" comes to firms like mine to compute those values that go in those PFD's and P&IDs and calculate those parameters and we work out the logic based on what they want.
Hopefully I educated you now. Feel free to subject everything I have posted to any qualified authority you wish and see what they say. Then you will learn.
Nope, I have gained anything new from your comment, as you didn't actually provide anything new to this topic in your response to me.
The truth of the matter is that a lot of car manufacturers supply brand new vehicles to customers that include temperature gauges that do not move until the coolant temperature hits certain ranges of temperatures. I, and many other consumers, have seen this behavior from multiple vehicles first hand for quite a while.
The temperature senders that are in the coolant stream do provide the ecu with the correct value as the coolant changes temperature, but the coolant gauge does not relay that information to the vehicle operator.
You are claiming that they do not do this, and that all automotive gauges change position with every degree of temperature fluctuation. You are incorrect in this supposition.
So, regardless if you want to claim that you were providing "facts", they are, unfortunately, incorrect, and thus, therefore are not facts.
Sometimes, actually going out into the real world, and looking at actual behavior will help you understand reality.
BC.
That’s not nice but with all due respect I have forgotten more on this subject than you will probably know in 3 lifetimes ( and that’s being polite) because you appear to interpret what you think you see in terms of anecdotal reasoning rather than the physical science that put it there.
The “truth of the matter” is exactly what I said and I can take you to the molecular level if necessary but I digress because you are entitled to your own opinion but not your own truth and I am not here to convince you.
Here is your first error
Go back and read carefully. I said no such thing. (Thus the term hysteresis). I can guarantee you that if you take that gauge away from its sending unit and plug it into the test rig it will read in almost real time what the signal is. Then you can disassemble this gauge and show the “mystery buffer” that makes it hold a given range. When you don’t find that miracle part- go back and read more carefully paying strict attention to detail. You may learn something if even by accident.
Then this
Negative Ghost Rider. What you need is a learning annex in thermal dynamics and instrumentation. (Might not hurt to add a course in control system design too) What you failed to do in any measure was show any factual error in anything I said. Unless that happens you have no valid point to make and I for one will be waiting with bated breath to see one.
Finally this
Here’s reality. Over the course of 40 years I have been a part of designing, testing, building and maintaining lines and components that build a lot of things as well as complex troubleshooting that people use in everyday life. I not only live in the “real world”- this “real world” comes to our firm and those like us to do these exact things. I don’t need to understand “reality” near as much as you appear to need a fundamental education enhancement in basic science and high school level physics.
Sadly, you almost got it here but missed the mark
If you read and actually understood what I said, I explained this- that comment is proof you did not fully grasp it. I’m not even going to begin to go into the location selection being based on a critical metric criterion the designers calculated in because if you didn’t understand the basics you will not even be able to comprehend this.
I fully support your right to believe in whatever ghosts, goblins, conspiracy theories or mystery gauges you choose but those beliefs carry no force or weight whatsoever in the face of proven science and technology.
