Just curious as to your opinions of using Castrol Edge 5W50 (readily available) or Amsoil Formula 4-Stroke PowerSports 0W40 instead of the Polaris PS-4 5W50?
I've used Castrol oils in my trucks in the past & am leaning towards it when the warranty is up on my Ranger.
I read this opinion on a Ranger forum & just curious if there is any truth that the Edge wouldn't have the anti-wear properties of the PS-4
Quote:
Personally I think Amsoil is the best, or one of the best oil/grease makers out there right now. If I were you, I'd change the engine oil at 50 hours, but no sooner. I usually run mine 50-70 hours depending on the amount of hard running/idle time I'm putting on them at that time. I would suggest you run a motor oil made for your engine. The newer car/truck synthetics don't have the anti wear properties in the oil (because of the EPA) that you get when you buy amsoil powersports oil, or polaris oil.. so, I'd do that first.
I can't see changing the oil every 50 hours as I'd be spending more time changing oil rather than riding. Yes, there is dust in our area but not all the time, so I can't see that being a concern the same if you were riding in a sandy environment all the time.
