Originally Posted By: threeputtpar
Both engines look very good.
I still find it strange to see the timing belt of an engine on the driver's side of the car here in NA. It's akin to being forced to use your non-dominate hand for a day. Tasks would take a bit longer but after a while you'd get used to the idea.
The older Honda H, F, and B-series engines had the timing belt on the driver's side, with the exhaust manifold in front.
The newer K-series engine has is flipped, with the intake manifold in front and the timing chain on the passenger side. However, it's kind of a moot point because the K motors use a timing chain which doesn't need replacements like belts do.
