boxcartommie22
Thread starter
6.2 L[edit]
The 6.2 L (379 cu in) V8 is the main variant of the Boss engine. The V8 shares design similarities with the Modular engine family such as a deep-skirt block with cross-bolted main caps, crankshaft driven gerotor oil pump, overhead cam valve train arrangement, and bellhousing bolt pattern. In particular, the 6.2 L V8 features a 2-valve per cylinder SOHC valve train with roller-rocker shafts and two spark plugs per cylinder as well as dual-equal variable cam timing. While notable that they use a much wider 4.53 in (115 mm) bore spacing (compared to the Modular's 3.937 in (100.0 mm)), allowing for the use of larger bore diameters and valves. The 6.2 L V8 has a bore diameter of 4.015 in (102.0 mm) with a 3.74 in (95 mm) stroke. The 6.2 L V8 has lightweight aluminum cylinder heads and pistons but makes use of a cast iron cylinder block for extra durability since most applications for the engine will be trucks.[2]
The 6.2 L V8 went into production in early 2010 and debuted in the 2010 Ford F-150 SVT Raptor as a late-availability option. A limited edition version of the Raptor from Ford Racing called the Raptor XT features a high output version of the 6.2 L V8 with approximately 500 horsepower (370 kW).[3] For the 2011 model year, the 6.2 L V8 was introduced in Ford's Super Duty pickups as a replacement for both the 5.4 L Triton V8 and the 6.8 L Triton V10 and in the F-150 as the premium engine option, though it is not available in all configurations
