If this has been discussed, my apologies - I didn't find it.
It seems that the standard starter design for automotive applications has become the gear reduction type, so I need to come up with a grease for the planetary drives in these to keep my small fleet starting.
Dow Corning makes a grease specifically for this application, Molykote 7514. It is a NLGI 1-2 PAO/Ester Lithium based grease. Perfect, I imagine, but you can't get it - unless you need industrial quantities.
These drives don't really need too much in the way of lubrication, I believe, but they need some, and the most compelling need, as I see it, is the lube needs to have excellent low temp. performance. I'm sure that using the usual automotive grease would lead to disappointment when hitting the key at -45f.
I've been thinking synthetic aviation greases like Mobilith SHC 100, 220, or 460 - I haven't decided. I would appreciate opinions on these, and other alternatives. The starter I currently have apart appears to have a ABS plastic gearcase, so rubber / plastic compatibility is a factor. And it needs to be readily available in tube or tub quantities.
Thank you!
Thank you!
