Quote:
CVTs are not good for high speed, or for direct feel or quick response, so we ruled CVTs out right away,
Don't tell that to Subaru.
http://www.carreviewsoup.com/mazda3-reaches-for-the-skyactiv
Article is a few years old.
Quote:
The Skyactiv 6-speed automatic uses both a torque converter that locks up at only 5 mph, plus a wet clutch, and a Mechatronic module to communicate between engine and transmission. The engineers met their targets. The torque-converter’s assets are used for smooth launches and intuitive low-speed control; eliminating torque-converter slippage above 5 mph improves efficiency and gives a direct connected feel, much like a manual for response; and designing Mechatronic’s to provide quick, responsive and smooth shifting.
“At Mazda, we wiped the slate clean, and started out with a conventional automatic with planetary gears, then set out to eliminate the blemishes, which are torque-converter slippage, indirect feel, slow shifting, and rough downshifts. We use both a clutch and torque-converter, which locks at 5 mph, because you must have some controlled slippage at low RPMs, but slippage is bad at higher speed.”
