Originally Posted By: Shannow
Originally Posted By: eddy21
Using a thicker oil plays [censored] with the variable valve timing components..
Yeah, those fords running the 5W20 only work between 95C and 100C oil temperatures...because at 32F, MC 5W20 is FIFTY times as thick as at 100C, and clearly the variable valve timing doesn't work at those temperatures...
or does it ?
The VVT doesn't work well with thicker oil myth continues. Lots of cars with VVT are running around Europe with 0w40 in the sump.
I guess i missed the dead engines littering the streets and dealer service bays flooded with non functioning VVT systems.
Lots of Honda ivtec engines running around here also with 0w40 in them and it was -25c a few times this past winter. they all did just fine.
or does it ?
