Originally Posted By: UncleS2
Outstanding!
It looks as though it could be factory, too. One thing that someone else mentioned above: the throttle shaft, over the years will wear & enlarge the holes is rides in, allowing extra air into the intake. This will roughen the idle, reduce power by a bit, & also allows a bit of unfiltered air into the system. It's pretty easy to check for. With car well warmed & idling in the driveway, get a cup of water, & maybe a straw or piece of small tubing Load the tubing with water, keeping a finger or thumb over the top end. Put the other end near the throttle shaft junction, rev the engine a little, & release a little water. If it sucks it right in there, best to get it fixed. Best is to enlarge the holes the shaft goes through, & than have fitted bronze bushings pressed in. That will outlast the original, which is a steel shaft in plain old aluminum, and if it ever needs doing again the process is a little simpler & less expen$ive. You'll need a shop that can have everything perfectly aligned & bore all holes in one pass- and such shops may be rare these days. Good news- I'd expect them to be reasonably easy to find via the internet these days. Just hit websites for old cars with twin/triple SU carb setups, like old Volvos, MG's, Triumphs, Jaguars, Austin Healys, etc.
Agree.
I did not want to comment on the Carburetors too much, as you say they have been 'sorted' and you did not mention that there was an issue with them.
I did ask about the throttle shafts, as it is a common area of neglect on old SU's that have spent their life 'away from Europe'
I am NOT an SU expert, but I have been working with them and on them for about 40 years now. so I guess I might know a little more than most people, and I'm afraid to say I have very often seen some REAL horrible work inflicted on constant depression carburetors this side of the Atlantic, so I advise you to beware!
SU (essentially) are still in existence in the UK under the name of Burlen Fuel
[url=Systemshttps://burlen.co.uk/][url=Systemshttps://burlen.co.uk/]Systemshttps://burlen.co.uk/[/url][/url] they keep a full stock of parts for virtually every SU made since 1930. They know their stuff, but can be a little difficult to deal with, as they expect you to deal only in SU part #'s and don't tolerate Layman's talk for very long.
State-side I would highly recommend that you deal with
http://joecurto.com/ who offers full service and uses only quality components.
With regard to Throttle shafts, these, as stated tend to wear into the Carb body and allow Air leaks. The latest SU rebuild kits now come with Teflon lined steel carburetor body bushings that all but eliminate this problem. The only problem is, you will need to get the body reamed/Line bored to accept the oversize bushing. and this is a precision job!
Another area of neglect is the metering needle and Jet. On your HS6 Carbs the needle is called a Biased needle. that is; the needle is Biased to one side of the jet by a small spring. As the needle moves in and out of the jet (in normal operation) it will tend to wear the jet hole Oval AND cause a Flat side on one side of the metering needle.
YOU CANNOT REPLACE THE METERING NEEDLE WITH ANY OLD SU NEEDLE!
There are several Hundred needles that will fit your Carburetors. Only one will be right for your application!
Despite what others may tell you, once set up properly, SU's can be very reliable, require little maintenance and give excellent performance. In fact the saying goes: "Most problems with SU's are ignition problems" meaning, people start to remedy poor running due to ignition by playing with the Carbs, and trying to fix what isn't broke.
With regards ignition, I would highly recommend a conversion to Electronic ignition. There are some great conversion kits out there like Petrinix
http://www.pertronix.com/prod/ig/ignitor/default.aspx they are invisible under the hood, can go a long way to eliminate problems within an otherwise worn distributor and will even allow you to go back to Points at a later date, if you so wish.
