Worked in transmission for a year after Uni, and attended a lecture on transformer UOA.
Imagine a big steel box, and sitting inside it laminated iron cores, wrapped with copper conductors, some as thick as your thumb, and insulated with what's essentially craft paper...then vacuum filled with insulating oil, highly refined mineral oil, with some Anti Oxidant, and alkalinity additives.
UOA is regular (monthly), and tests for
* electrical resistivity (oil contamination and breakdown)
* reserve alkalinity
* moisture
* oxidation resistance
* furans (indicate that the cellulose is breaking down due to age/oxidation, or internal sparking)
* traces gasses (ratio of N2 to O2, CO, CO2, CH4 tell a lot about what's happening inside).
Anyway, the lecturer stated that he could tell a lot about the future working life of the Transformer oil, and the transformer itself before he took the sample, by visual inspection for oil leaks.
Pretty common in any switchyard, I've included the pic below, of a typical, and common oil stain from a gasket (and a bloke patching the leak).
Question is
Why did the transformer UOA expert state so emphatically that he could "tell a lot" about the future working life of a power transformer by the presence of gasket weeps ?
* moisture
Question is
