Originally Posted By: boxcartommie22
called ford motor co. performance group. ford is changing over to newer engines. the 6.2 l will be in the trucks above f250 and he said the 6.2 and 5.4 is in the same family bottom end the same the stroke and head are a bit different. the raptors will have a v6 double turbo yields above 411 hp.also he said the raptor uses 5w20 oil you can definitely use 5w30 red line he said is a high end oil.
That's not correct info. The 5.4L is shorter (length-wise) than the 6.2L, which has 4" bores, whilst the 5.4L does not. It (the 5.4L) is the same, length-wise, as the 4.6L, which is also the same length as the new 5.0L. The 6.2L is a much larger engine than any of them save the 6.8L V10.
More info:
5.4L Ford: 90.2mm bore, 105.8mm stroke, bore spacing 100mm
6.2L Ford: 102mm bore, 95mm stroke, bore spacing 115mm
