I am going to run a test of an 8 cubic inch Briggs Engine. I have mixed 30 cc TC-W3 per gallon of gasoline. The engine drives a generator. I have a digital KW meter which counts time and KWH. I intend to do at least a 5 hour test on the oil in fuel and on the regular gasoline. I have a brand new spark plug installed for each test to try to eliminate erors.
Should be interesting. I'll post the results.
