use whatever you like...it's your ride
currently I have a bit over 5 liters of a 'franken-blend' that is a mix of Havoline conventional 10w-40 pcmo, BelRay conventional 10w-40 motorcycle oil, SuperTech conventional 15w-40 hdeo, and maybe a bit of Quaker State conventional 10w-40 pcmo; this blend will be used in both bikes this season with shorter OCI's of 1000-2000 miles (a new filter every 4000 miles on the Honda Shadow and every 3000 miles on the Suzuki GZ250); the blend is also my roadside/top off oil for this season and winter storage oil for winter; I also use this as cleaning/lubricating oil for my firearms...
the only exception to usingsuch a blend for me is in a 2-wheeled machine will be during the warranty period if I decide to get a new Piaggio based scooter (Vespa, Piaggio, Aprilia) which indicates a 5w-40 (in such a case I will use Chevron Delo or Shell Rotella T-6 or Mobil 1 truck oil)
I believe JASO MA/MA2 rating/certification is a 'checks & balances' guidemark for warranty use by the bike/scooter/atv manufacturers...
