Originally Posted By: 01_celica_gt
Peak Long Life, it says they have OEM Honda approval, I use that in all my toyotas and hondas now, they all have OEM water pumps with no leaks...easily have more then a million miles on all the cars I now maintain for the family, I only changed the thermostats because the springs were getting lazy and the heat up was slower is all.
The only OEM approved coolant for Honda is the Genuine stuff.
The Peak stuff is recommended for Honda applications, but is not OEM approved.
With that said, I just did a used car prep for an Acura RSX and filled the system with the new improved version of Prestone All Makes. I probably wouldn't use it if the car was being kept, but....
