Here is an interesting short article about truck tire balancing:
http://www.tirereview.com/commercial-tire-wheel-balance/
Some excerpts:
"………..Most importantly, recent information published by the S.11 Energy Conservation Study Group of the TMC shows that balancing all wheel positions on over-the-road rigs can save up to 2.2% fuel compared to non-balanced assemblies, regardless of truck ride considerations……"
"……..it is widely documented that all radial truck tires have reduced rolling resistance as they wear, with new tires being less fuel efficient (up to 6% difference) than their worn counterparts………"
"……..A typical linehaul 295/75R22.5 drive tire loses approximately 30 lbs. of tread rubber from new to a popular pull point of 6.5/32 depth remaining. Practically, this mass change means that periodic re-balancing may be required to maintain optimum balance and performance as the tires wear…………"
Some excerpts:
