Kawasaki's oil recombinations are based on using conventional oils, but there only recommendation is using an API SF,SG,SH,Sj or SL. Since those are all older ratings, you can use the latest API SN, since it is backwards compatible. I have a Kawasaki FR730V and saw the oil recommendation are identical. But Kawasaki does not ban synthetic oils, they just don't recognized the benefits of then. So according to there oil recommendation and put it in synthetic oil equivalent, either use a Xw30, or Xw40 and use it at both temperature extremes. Of course if you are concerned about warranty, your most easy to get synthetic oil within recommendation is 10w30. Being in Alabama, a 40 grade oil would probably work better, but there synthetics are usually in 0w40 or 5w40, so you may either stick to 10w30 synthetic oil, find a 10w40 synthetic oil and pay who know what, or stick to conventional oil till your warranty runs out. As far as oil consumption with multi grade viscosity oils, that is typical in most OPE manuals, but believe synthetic oils are better than any straight weight oils. I would still check your oil, but I doubt your consumption will be worse than a straight weight conventional oil. You get the best of both worlds with synthetic oils. I know there is a lot of BITOG who likes using diesel oils, but not required. I use a name brand 5w30 synthetic oil that I find for a good price in my mower, run it a half hour at a time, put 40 hours on my last oil and did not have to add any, does not smoke upon start up. Briggs and Stratton recognized the benefits of synthetic oils and there synthetic recommendation is 5w30 at all temp. extremes, so why not on a Kawasaki?
