I don't know but I know the frontier's from 2005 on are a nightmare. You gotta replace the reservoir and radiator cap every 30K if you don't want air getting in the system. Started happening to mine shortly after 30K, started noticing it on take off with water rush noises and heater not functioning properly. They use the reservoir cap as the pressure relief in this set up. My understanding is the heater core is a bad setup on it and has a tendency to draw air from any weak point in the system. I still have a little air in mine at 44K after replacing the caps, tried bleeding it, squeezing hoses, but I am not going to pay a dealership to do it as long as its not affecting anything. BTW the reservoir went dry in mine, guess due to vapor release from the cap or the radiator was releasing it in very small amounts over time, just a guess on what happened with mine.
I did the bleeding with the cap off as it warmed up, they tell you to race the engine to 2500rpm to 3000rpm for 10 seconds and to place the cap on if it tries to overflow the neck. I did that 3 times, made a mess, it would also suck a lot from the reservoir while doing this and I still heard air in the heater core (I kept the core open all the way during this as it says). Best effect I have gotten so far was to do that, put the cap on, rev it, take the radiator cap off, air will come out, do that a few times, then take the cap off and leave it off. Squeeze the heater hoses and more air will come out while the cap is off. Doing this got rid of most of the air in my system. Undoubtedly this is a common problem with Nissan.
