MAKE/MODEL: Nissan 5.6L V-8 VK56DE OIL TYPE & GRADE: Mobil 1 5W/30
FUEL TYPE: Gasoline (Unleaded)
OIL USE INTERVAL: 6,500 Miles
ADDITIONAL INFO:
BRYAN: This sample from your Titan looked pretty good. Universal averages show typical wear
levels for this type of Nissan 5.6L engine after ~5,500 miles. You went ~1000 miles past that, so the iron (which typically increases with mileage) didn't cause us to raise an eyebrow. With other wear metals lining up so nicely with averages, we can only assume you have one happy, healthy engine in your truck.The TBN was strong at 3.3, so extended oil use intervals would be a great idea for you -- otherwise you'd be wasting good oil.Go ~7,500 miles next and check back.
Code:
ELEMENTS IN PARTS PER MILLION MI/HR on Oil 6,500
UNIT / LOCATION AVERAGES
MI/HR on Unit UNIVERSAL AVERAGES
Sample Date 03/01/15
Make Up Oil Added
ALUMINUM 3 3 3
CHROMIUM 2 2 1
IRON 20 20 13
COPPER 1 1 3
LEAD 3 3 4
TIN 0 0 1
MOLYBDENUM 72 72 69
NICKEL 0 0 0
MANGANESE 0 0 2
SILVER 0 0 0
TITANIUM 1 1 2
POTASSIUM 1 1 2
BORON 40 40 51
SILICON 16 16 13
SODIUM 11 11 30
CALCIUM 1097 1097 2230
MAGNESIUM 624 624 179
PHOSPHORUS 658 658 693
ZINC 796 796 813
BARIUM 0 0 0
PROPERTIES SUS Viscosity @ 210°F 58.6 55-62
cSt Viscosity @ 100°C 9.81 8.8-11.1
Flashpoint in °F 375 >365
Fuel %
Antifreeze % 0.0 0.0
Water % 0.0 0.0
Insolubles % 0.3
TBN 3.3 >1.0
Changed earlier than planned since I was doing the 100K mile service, Planning on going 8500 next time. Bosch D+ Filter
ADDITIONAL INFO:
Code:
Make Up Oil Added
ALUMINUM 3 3 3
CHROMIUM 2 2 1
IRON 20 20 13
COPPER 1 1 3
LEAD 3 3 4
TIN 0 0 1
MOLYBDENUM 72 72 69
NICKEL 0 0 0
MANGANESE 0 0 2
SILVER 0 0 0
TITANIUM 1 1 2
POTASSIUM 1 1 2
BORON 40 40 51
SILICON 16 16 13
SODIUM 11 11 30
ZINC 796 796 813
BARIUM 0 0 0
Fuel %
Water % 0.0 0.0
Insolubles % 0.3
TBN 3.3 >1.0
