Originally Posted By: Ducman
Originally Posted By: dailydriver
Yikes, a 5.95 cst @100*C, WAY TOO THIN for the T56!
The T56 should be using a dedicated MTL
It WOULD have an MTL in it IF Red Line, Amsoil, Motul, etc. would
ever make one with < an 8.5 cSt @ 100*C.
I've tried almost all of the others on MolaKule's list, and NONE of them worked well in winter ambients (even when somewhat warm), or until FULLY hot even in summer ambients, so it got the old T56 standby, D4 ATF (one of the most 'stout' Dex 3s in existence).
That being said, this summer, I may give the Amsoil MTF (9.6 cSt @ 100*C) another chance.
You could cut the Amsoil MTF with their ATL in varying ratios to get the desired result.
Back in the old days we tried all sorts of things to get proper synchro operation.
That included mixing SAE 30 motor oil with different types of ATF which were available at the time.
Also Castrol VMX 80w worked extremely well as a dedicated GL 4 gear lube. But it's a mineral oil if your prejudiced.
Alternately if you can get it, something like Penrite Pro Gear 70w-75 is a dedicated synthetic gear oil developed for the T56 type applications.
By all accounts it works very well, as well it should because the relevant viscosities are very similar to DEX II/III.
Thanks
, I will have to call Summit Racing (the ONLY place in the states that even knows what Penrite is) and see IF they can get that, but I fear the co$t (I would expect >$30.00 USD/liter).
I have mixed the Red Line MTL & D4 in the past, but ANY MTL at all will raise the cSt above the requisite Dex 3 level of ~7.5 cSt @ 100*C.
I may try the Amsoil MTF, blended with their Signature Series ATF to at least get thinner yet, since the MTF starts thinner than Red Line's MTL.
