Originally Posted By: edyvw
Originally Posted By: 4wheeldog
Getting actual certifications is expensive, so a relatively small independent producer like Redline tends not to spend the bucks. It is of unrivaled quality, but as the other poster pointed out.......Mobil 1 is better than it needs be, cheaper, and readily available. Redline can only be incrementally better, if it is better.
Getting actual certification, meaning sending oil for certification is not expensive. I was part of that process, testing VW504.00/507.00 oil, and small producer send it after all tests to VW. That part is cheap, when it comes to that case, it was around 3,000 euros. RL and others are not doing it probably bcs there is something there that they think is beneficial to oil, but maybe is problem when it comes to certification.
First rebuttal to the claim that certifications are expensive.
RL is not cheap anywhere. eddyw raises some valid points here.
What is RL's real driver for lack of certifications for the oils, if 3000 Euros is correct then that is cheap, so it can't be the cost hmmm....
