I had a Cast Iron pan for over 15 years.
Cook steaks over an open fire, bacon and eggs etc.
You can throw sand in them and rub it around then just rinse with water.
Dry it and put corn oil on it, and you are good for next time.
People speak of complex cleaning of them. I don't get it.
Cast Iron is super easy to clean. YOu can even cut in the bottom of one.
Sunlight dish soap is a great cleaner as it isn't strong enough to harm the seasoning.
Dawn dish soap will remove seasoning, don't use it.
Or, use Dawn once in a while so you can build up a new seasoned layer once in a while.
Is there a way to ruin a Cast Iron pan?? Even rust pits it and after it seasons the pits cradle oil and makes it even more stick-free.
Teflon pans are the dumbest invention in the world.
I want a Cast Iron pot!!
