I have an '04 Odyssey which I'm repairing head gaskets on. I've pulled both cylinder heads and am ready to take them to the machine shop and have them checked for flatness. I want to have these cylinder heads reconditioned, but I'm not sure what that entails. This is the first time I've done head gaskets, and given all the work I've put in thus far, I want to put the cylinder heads back in as "refreshed" as possible, within reason.
What I'm not sure is how far the machine shop will go in rebuilding the head, or what work I can do on my own. I don't really know what a valve "grind" entails, replacing guides, seals, etc. mean, as I haven't taken the cylinder head apart (and not sure if I should, given that the machine shop will be doing some work to it).
Typically when you approach a cylinder head rebuild, what work does the machine shop do, and what is done in the garage? What parts should I order ahead of time? Are there parts I will need to supply to the machine shop? Should I buy new valves, cam, or is replacing hard parts unnecessary?
Any info describing a typical rebuild, the different steps, and about how much the machine shop work would cost would be much appreciated. I have plenty of mechanical ability (or I wouldn't be attempting a head gasket repair), I've just never dove into the inside of a modern DOHC cylinder head before.
This was a used vehicle purchase where I discovered a leaking head gasket after purchasing it. The head gasket leak was only leaking compression into the cooling system. No oil or coolant mixing together, just would burn off coolant at a slow rate, and I'd have to top it off every couple hundred miles or it would overheat. Some bubbling into the overflow tank. Looking at old service records, the brought it into have an overheat condition diagnosed and the mechanic just threw parts at it. So presumably, it was driven while overheating long enough to warp the head and/or take out the head gasket. Only the front bank is affected, but I'm doing both while I have it all apart. Please educate me, thanks in advance!
