Originally Posted By: Greasymechtech
Use whatever you want. Compare all your choices and pick one that sounds/feels the best.
Jackpot.... only if the PSF, ATF, BF, coolant, diffs and transfer case have been serviced and topped off as needed.
The only things I hated with my 5.7 was the plastic oil filter cap(easy upgrade to aluminum), enriching the gas refineries, and the JBL amps that kept blowing.
It has full service records but never had an ATF change to my knowledge. I have been a big proponent in ATF changes around 30-40K however, this 5.7 seems like a pain in the a$$ to do ATF. No drain plug and dropping the whole pan?? From limited research, I will likely go with the Toyota ATF - I like Redline ATF for my Acura, but Honda ATF sucks and this Toyota ATF seems to have gotten it right.
I changed the rear differential fluid with some Redline. No transfer case on the 4x2.
I am doing all 4 brakes this weekend and will bleed and change out the brake fluid.
PS - haven't done anything
I should probably do a radiator flush and fill
I agree with the oil cartridge sucking - the cheap plastic cap wrench I bought from Advance was "compatible" which apparently meant worked with duct tape shimming. I need to do something different there.
Other than that, I will likely do spark plugs... I assume they were supposed to be changed at 100k, but don't know what the book says.
