A long time Toyota Mechanic tells me this about Toyota Water pump leaks on engines such as the 25L and 2.7 L (2.5L comes in camrys for example)...
QUOTE
If you really want to get rid of water pump problems, switch to red coolant but you'll have to replace it every 30,000 miles and kiss your warranty good bye, but at least you won't have leaking water pump. THE Super Long Life EASTS THE METAL GASKET ON THE 2.5L THATS JUST HOW IT IS.
One note to anyone replacing their water pump on a 2AR-1AR engine which is the 2.5 and 2.7, The gasket is made of the cheapest junk china can make so it's very common to seperate when you take it out and leave residue, enough residue to cause the new gasket to leak. Make sure you scrape the contact surfaces real good before installing the new gasket and pump.
Taking this into consideration... with the fact that member MechanicX has explained in other posts that Toyota Long Life uses benzoate and the newer (more problematic)Super-Long-Life uses sebacic acid, which is related to sebacate. Sebacic is a type of carboxylate and is a plasticizer.
IS IT A GOOD IDEA TO GO TO TOYOTA RED? (Long Life is what they call it)
QUOTE
