Originally Posted By: k24a4
Originally Posted By: HTSS_TR
You should keep in mind that after sale services are importance. Local tire store can do rotation within 15-20 minutes if you have appointment, since the Accord is front wheel drive you need to rotate the tires about 5k, if BJ will rotate the tire first comes first serves you may wait up to 1.5-2.0 hours like Costco. Do you like to waste extra 1.5 hours every few months ?
Good point. I am not familiar with BJ's tire service but this will be a good question to ask. The local dealer does have "lowest price guarantee", but as we know, this can be left open to interpretation. I have been satisfied with their service-usually 20-40 minutes for rotation and balance.
600 OTD for 4 Premier AS tires is a good price and is similar to what I paid at Costco.
My local Costco takes appointments for tire rotations. However, if your store doesn't, one tip that I can give you is to go just before the store opens for the day. The line is usually shorter at that time. It's also better to go on weekdays than weekends.
Overall, I've been pretty happy with the tire service at Costco. I'm not sure if BJ's does the same, but one good thing about Costco is that they hand-torque your lug nuts with a torque wrench to manufacturer specs instead of over-torquing them with the air wrench. They even suggest that you come back after 50 miles for a torque check!
By the way, if there are no wear issues on your current tires, then you may be able to get away with skipping the 4-wheel alignment. As long as your current tires are wearing evenly, then there shouldn't be any issues with the new tires unless you happened to hit a big pothole right after getting the new tires installed. On our Accords, the only aspect of alignment that can actually be adjusted is toe, and it's rare for that to go out of adjustment unless you've been in an accident or hit some big potholes. (Adjusting camber is possible, but not without aftermarket camber plates). If you want to get a quick alignment check, most Honda dealerships will do it free of charge and will give you the printout afterwards.
However, I understand that doing a 4-wheel alignment can give peace of mind, so do what feels right to you!
