I've got a question for some of the big guns here, and hopefully it's in the right section, since it is about the science and technology of oils - albeit in the crude state. It's not about formulation; it's about petroleum engineering.
A number of days ago, a petroleum engineer came to see me, wanting to know if there was a way to calculate density on hydrocarbon compounds with more than 65 carbon atoms on first principles, for something he was doing with his graduate project. He had data for the various compounds with up to around 65 carbon atoms, but his sample had compounds with greater than 65 carbon atoms, and he was running into problems at the polymer injection phase.
I told him that such data would have to be established experimentally, and I don't know of a way to come up with a concrete density value for a given hydrocarbon by way of calculation. I told him when I need a value for a known compound and don't want to or cannot obtain it experimentally, I check the compendium, but it's not going to have something like he needs. I sent him off to the chemistry department in search of an organic chemistry prof and see if they had any ideas, and, barring that, to head back to engineering and find one of the polymer science guys, since they would have an approximation.
It turns out the latter answer was the correct one for his project, and there is an approximation for such samples. However, is there anything obvious that I've missed?
