I just ordered new hoses, trying to think of other variables causing my driver rear brakes to stick. I suspected my sticking driver's rear is brake hose related. At first when I noticed by rear brake dragging, I found a seized slide pin, completely frozen inside the metal sleeve within the rubber bushing. Replaced it, cleaned everything and re-greased. I thought that was it.
At assembly, I noticed the piston would not retract at all unless the bleeder was cracked, and this was using a beastly C clamp. I thought nothing of it since it felt fine during the test drive, but after 10 miles of driving it froze up again. It's obvious, since there's an incline near my house and if all is well, I'd roll back down it in neutral. The hoses are probably oem from the year 2000. I think the caliper is fine since it did finally retract pretty easily. It was a reman from Autozone two years ago. Anything else I may have missed?
